TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Re: Re: engine chatter lifters. rod , bearings?
Subject Re: Re: Re: Re: Re: engine chatter lifters. rod , bearings?
Posted by CmyZ on February 18, 2011 at 8:48 AM
  This message has been viewed 138 times.
In Reply To Re: Re: Re: Re: engine chatter lifters. rod , bearings? posted by ttzxna on February 15, 2011 at 05:09 PM
Message First check if you oil pan is dented like indicated above, and fix it by replacing the oil pan and making sure the pick up tube is not bent. It also sounds like a VTC intake cam gear.
